[MOD][THEME] Custom Themed Dialer Pads
Re: [MOD][THEME][FROYO] Custom Themed Dialer Pads
Hey man, I've been searching for custom dialers for the motorola photon, but haven't found any. will this method of making dialers work for the photon or just the epic and do i have to be deodexed? Thanks
My partner ZiggSvo had the Photon in its early days but never got far enough along to see if this method worked on the Photon.
Deodexed/custom ROM on your Photon..
Reactions: Admiralj21
Cool, and thanks for the reply. I will continue to see what I can find. I am deodexed by the way :-)
Paul, are you still doing this, and if so, will they work on ACS ICS v5?
If this is the case, would you be willing to do these two (one for the wife and one for me).
Thanks in advance!
Thanks in advance!
Sorry but I am no longer supporting these dialer pads. I have a very full plate working the NS4G area, my theme and just being an adviser in general.
If you were to follow my instructions in the HOW TO guide I'm sure you could easily pull this off for yourself with EI22/EL30 Gingerbread.
I can't seem to get the diskette on my epic 4g. I opened the pak and changed the setting to accept non market apps but when it loads, it says "app not installed". ? Help?
photo.php
can u please make a dialer theme with this image for a jelly bean style dialer? thanks
i have samsung galaxy s GT I9003 and while i was rooting it i unplugged it by mistake......so when i turn it on the galaxy start up stage freezes.... so i put it on odin and put PIT file but i forgot to uncheck RE-Partition and now all i have is a black screen when i turn it on.... pleasseeeee helppppppp
amateur_user
