Mods and Add-Ons
Can I just flash it over my current rom or do I need to wipe everything. Thanks for the quick replies.
I went 2 to 3. I like it a lot better. Just do the davlik wipe and then flash. Then apply fixes like audio fix.
Do nand backup first just in case. Also do nand backup after your done and before live wallpapers. I went back to regular 3 after trying Live wallpapers using nand restore.
Does anybody know where I can change my lock screen to look like the Nexus One with the left-right slide bar? I am rooted with 2.1.
I love the way it looks, but the lockscreen really killed the whole thing for me. Is there some way to get rid of the lion logo, and if not, how do I go back to that standard sense theme?
I haven't had time to try that zip,but if you made a nadroid backup then just restore with that.If not then either reflash rom or later today ii should have up zips to change everything back to stock.
I still need to get the zip together for that,but they do have it up on xda.
Technically, you can just remove /system/App/HtcLockScreen.apk
If you go this route, don't use the alarm clock, you will not be able to shut it off.
lol...thats why i didn't put that up cause i figured sum people would over look the alarm part.:eek:
Could you show us how to get the Expresso Lock Screen add on?
I have the files almost ready for it just wanting for my slow cp to boot so i can finish it.If you want i could just give you the three files to make just expresso lock.
liquidsnake757
