Moto G5 Plus
PaulRavin
19
I have a Moto G5 Plus and use Textra for messaging. Been using it for years with no problems.
Then two days ago I was answering a text and then closed Texta and opened it again , like always, and was greeted with all phone numbers that are usually in my Contacts. So I closed Texta and opened Contacts and No Contacts were found. Been searching for the answer but have not found one yet. Thanks for any help.
1. To back up what's on Google Contacts, you can export (bottom of the left column) right from the site. If the contacts disappear, the backup file will get them back.
2. To back up texts (not proprietary format - SMS type texts) use SMS Backup & Restore.
(Almost everything can be backed up before you do something that might get rid of it.)
Hello All,
Sorry I am a little late but had an eye Dr. appointment today.
Well nothing has changed even with the Contacts now turned ON in Textra . So back to square one.
Want to say hello to Rukbat and yes I like to back up everything if possible just in case something goes wrong. Textra has both SMS and MMS (for pictures) and from what I have been reading most SMS backups will not do MMS , so a little problem there.
Hello All,
Can you confirm no issue on the native text app ?
Because if you don't have it disabled and delete data in textra they should all be in your stock app
Hi , mustang7757,
Yes, in my Old , native text app , I have not used it in years and it is Disabled and there is No data left in that Old app.
In the Textra App the only thing I have showing now , the problem , is the phone numbers and when you click on a phone number it does show the text , so it is still workable for texting. It's just I don't know who's phone number goes with who's name. Also in the Contacts I have NO Phone Numbers.
Hi , mustang7757,
Ok download Google messages and see if everything populates there , or is that the stock message app ?
Hi mustang7757,
Not sure I have it right but you want me to Enable the Old Messenger App to see if everything populates there ?
Now the question I have can you have Two Text Messaging App running at the same time ? Because the Textra App has to stay running because it has All the Phone Numbers in it.
I don't have any Google Messages App at all on my phone.
Hi mustang7757,
Hi,
Yeah if you enabled the old message does it populate there?
We start with this first.
Hi mustang7757,
Well I just enabled the App Messages and waited until it finished calculating then opened the App and it was empty.
No texts or names or phone numbers. The only thing I can say it looked like was the Contacts that is suppose to have all the above but does Not.
I have also been surfing different forums to see if my problem has ever happened in the past and it has.
I ran into the forum AndroidForums and found some people had , what appears to be the same thing , back in 2016-17.
Several things were tried and some worked of some but not for others. The thing is it seems to be with a lot of different makes of phones too.
Ok so something really off , I would start making a back.up with rukbat suggestions on that app, it won't do picture so any important ones use Google drive or Google photos and store them there , they just won't be back in text messages back up. This looks like it will end up going factory reset .
Try one more thing , go to settings >accounts > you see your Google account? Look for back up and tell me last time and what things mention back up ?
Yes , I think the thing that is really the cause of this is the , Contacts , no longer on my phone . I think if they were there some of the things I tried would have worked, even taking out the dup's I had in my Google account online where I have 93 Contact phone numbers now , though that would have corrected it but it didn't.
Ok the Google account in settings>accounts shows Two of my email addresses . When I tap on one of them it shows Calendar Last synced 12/5/20 at 1206 / Drive Last synced 12/4/20 at 1851 / Gmail Last synced 12/5/20 at 1732 / Google Calendar Last synced 12/5/20 at 1206 / People details Last synced 12/4/20 at 1311 / Tasks in Calendar Last synced 12/5/20 at 1206 and the other gmail show just about the same with maybe + 2 or 3 hours difference in time.
If it comes down to a factory reset , I will just go out and buy a new phone . Maybe that's what it's trying to tell me.
Nothing about messages or contacts?
What device do you have in mind if u do?
Nope , nothing about messages or contacts , that's why it is going to be hard to back up things.
Well I was thinking of staying with the Moto Line and looking at the Moto G Power.
Well I got a semi fix to the problem. Went to the Google Contact site saw all 93 Contacts there Connected my phone up with a USB to my computer and phone found a sync button clicked it and it did a quick transfer of the contacts but on the bad side it only transfer 19 of the 93 Contacts. So I will have to settle for that and I don't know what happen to all the rest of them but at least I got it to work.
So I will have to leave it as SOLVED. . .
At least you know it's back up.in google cloud , maybe log out your google account on the device then log back in
I am going to have to do some more research on some interesting items I came across : Export to a .VCF file and same to a CSV file.
Also backup to a SIM card and a SD card. If I get a chance I may try all 4 ways , just for practice , and I will also have Spares in case anything goes wrong.
But the First thing I have to do is BACK UP those 93 Contacts on the Contacts Google Com site that I can get to from the Desk Top Computer.
In the meantime I think I will take a break from looking at this computer screen and do something else.
Thanks for all you Help mustang7757 it's good to know you guys are around when someone needs help. Have a good one.
alejandro109322
