Moto G7 problems after update to Android 10.
Should Google Play Services be running 1 hr 48 min on my phone? It has used 9%of my battery. Every once in awhile I see the arrow downloading in the notification area. I don't play games, if that has anything to do with Play Services. Trying to figure out why my battery is draining after Android 10 update.
Just after updating my Moto g7, my SD card alerted it was corrupted. My camera stopped working. And now it keeps telling me my account doesn't support phone tethering when I try to use the hotspot. My provider says the account is fine and directed me to do a factory reset. I did. Now I have a paperweight. Android 10 is a lemon. Even Windows Vista wasn't this bad.
Welcome to Android Central! SD cards can corrupt at any time -- it's not necessarily due to the Android 10 update. If you formatted your SD card as Internal Storage and the card corrupts, it can cause a lot of the system to crash. Did you remove the card before doing the factory reset? What do you mean that you have a paperweight after the factory reset -- is it stuck on the boot logo?
Android 10 has been great on my Pixel 3 XL. Remember that it's up to the phone manufacturer to tweak the base code so that it works correctly on their phones, so this would be more of a Lenovo issue than a Google issue.
maryhurst515
