Jamez Avila
Banned
- Nov 20, 2012
- 355
- 0
- 0
Yeah those gaps do not look good. thanks for sharing the pics...that saved me from buying the full ones!
Will a Hula bumper cover and mitigate the problem of raised glass edges? Anyone tried both?
Welp, I gave up on screen protectors or whatever they're called; utter waste of time. Long story short, this screen will scratch, and there's no getting around it.
Gorilla glass is just marketing mumbo jumbo, my screen is already scratched (only visible under certain lighting) and I haven't had the phone for two weeks. Only thing it has come in contact with besides my thumb is lint free cloth. I'm just not going to let it bother me. I'm going to be using the phone naked from here on out.
But to those of you who are OCD about this sort of thing, don't let the marketing nonsense fool you, the screen will scratch, get a protector if that sort of thing bothers you.
Ridiculous that after all this time they have't come up with a solution to this. Who is requiring theses screens to be glass exactly? Wouldn't some sort of high transmittance polymer be a better solution than using glass? Instead of making the glass harder wouldn't it make more sense to use something with a little resilience (i.e. elasticity)? Glass will always scratch ... It's brittle.
Anyway, just my 2 cents, and frustration with a supposed premium device.
The solution is sapphire
Devices slowly popping up with sapphire integrated in the screen
Once my phone will have a sapphire coating or sapphire incorporated the right way, only then I'll be cruising without a screen protector
Honestly, that sounds like trying to put out an electric fire with more water. Until they can develop a glass that can withstand > 7 mohs (i.e. sand) it's all moot.
Perhaps it's time to try another approach; maybe look for a material that isn't hard but rather elastic such that it doesn't shatter or suffer the other ails of brittle materials (i.e. permanent scratches).
Glass ones thicker than plastic film?
I found one!!!
As you know with the moto 2014 the edges are curved. i have had several glass screen protectors for it. if they are close to the edge it looks bad and has some gaps between the glass and the shield due to the curve. This one comes up a bit short on all the sides and as such fits flushly against the glass. it also does not look bad with a case due to the case has enough lip on it to make it less noticeable. it is also very thin so dragging things to the edges work fine. best one!
