Moto X KitKat differences & issues
Yay, they added hangouts to Motorola connect. Motorola connect and assist are also being pushed through the play store! I'm loving the backbone we're receiving from this phone. They really want to make this their iPhone. An android phone for the masses.
Sent from my Moto X
I don't think Google Now hotword is supposed to work on the Moto X. Here is the Verizon Moto X (with Kit Kat upgrade) manual from Motorola's site
https://motorola-global-portal.cust...irect/1/filename/Xfon_UG_Vzw_KK_17618001a.pdf
On page 13 about Google Now, it clearly indicates that you need to tap the microphone button to initiate voice search. Of course, you can always initiate with Touchless Control (ok google now). Perhaps they disabled it to avoid conflict between Google Now's (Ok Google) and Touchless Controls' (Ok Google Now).
I wish it worked though or there was a way to continue searching with the hot word while in Google now. Does the manual explain how to change the phrase "Ok Google Now"?
Sent from my XT1060 using AC Forums mobile app
I've been able to use, "OK Google Now" just like I used to use, "OK Google" on my Galaxy Nexus.
Open Google Now and try:
"OK Google Now, who is Barack Obama"
Answer
"OK Google Now, who is his wife?"
Answer
"OK Google Now, who are his kids?"
Answer
"OK Google Now, how old is he?"
Answer
You get the idea. Basically, I think in best interest of not being confusing and keeping the phrase uniform across the Moto X, everything that should be, "OK Google" is "OK Google Now".
My phone tends to go black for a few seconds after unlocking from active notifications. Very annoying. Other than that, no issues
Mine didn't do this at all until yesterday. Two days ago I sideloaded GEL, yesterday I enabled ART. After this combo I noticed the lagging if unlocking from active notifications. If I hit the power button it's instant, it doesn't do it consistently though as some times it works good sometimes not. I switched back to Dalvik but hasn't cured it. If you're also running GEL maybe that is the issue?
Answer
Answer
Answer
Answer
Mine works that way too. I was just surprised that they disabled Google Now/Search hotword launch. Google Now/Search and Touchless Controls are separate. I expected that with Kit Kat, I could turn off Touchless Controls and still have Google Now be able to do voice search with the hotword (like any Kit Kat device does).
What about battery life? Seems Wi-Fi drains it faster post-Kitkat
The first thing I noticed after installing kitkat is that the haptic feedback on the unlock screen has been toned down significantly.
Sent from my XT1053 using AC Forums mobile app
There are several people on Google plus reporting no change in behavior with battery... They also reset the device after the update.
What kind of reset are we talking about here? Thanks
for those with the lag on the lock screen turn off the lock screen security, check and then back on.
Just the lock screen or everything like calls and text and keyboard?
Q10, HTC One, Nexus 7, Moto X
The update is working great on my Moto X. Absolutely no problems to speak of.
I don't want kitkat until the bugs are fixed I just read that a bunch of Moto X users are having exchange email issues. That's a deal breaker for me
Everything's working fine for me as well. I'm just not nuts about the Favorites section in the dialer. I liked the huge icons and the fact that there was more than 3 in 4.2.
Kitkat takes away the blue battery and network signal??
BarishYadav
