Moto X: Strange notification sound
Yes, I have also suffered from this sound for 2 long days. Then finally I left my all job, sat in my room and started searching for all option and u can go like this
1. Check all the apps where u can set limits or condition which will promt notification
2. Give special emphasise to all new apps,uninstall it if u feel not necessary.
3. Check for NFC to be turned off
U would be trolled by what I found to be my reason of notification.
It was a ******* Sim Tracker app. I uninstalled it and sound gone.
Yeah.
Had the same notification "Bong" happening all of a sudden. Found out it was from my Plantronics bluetooth app when I turned of that apps notifications it went away. Note that I didn't show that I had the app. Had to reload the app to turn the notification off. BTW, Plantronics' tech support was great.
I too have a doorbell sound and it scares the crap out of me. Not expecting that sound. No new apps.
What is NFC?
Got the same sound - most irritating. Solved problem by uninstalling an app: Show Battery Percentage from Mobitop.
agahsha8
