Moto Z Play Droid: 7.0 Nougat
Got mine updated, no issues at all so far without issue. Google assistant is now working too but not sure if that is just a coincidence or not.
Are "app shortcuts" exclusive to 7.1.1? I'm not getting anything on long press with known apps.
Everything is dandy on Nougat for me except:
  • There's a glitch where if my phone is locked and I'm playing music (Rocket Player), the power button refuses to work so I can't see the lock screen. The only way to wake the phone is to use the fingerprint sensor.
  • Battery life SOT is slightly worse. I haven't factory reset, but I've cleared cache and most of my app caches as well. Doze on the go works well though.
Anybody else with these issues?
Re battery life - yes I have. But the difference is ever so slight.
My battery life is worse now. I really don't use my phone much and hardly listen to music or play games. I have 2 hours SOT and I'm at 70%. Before I would be at like 90% with 2 hours SOT
Try dong a factory reset and wipe cache partition. So far mine is just as good as the day I got it even with nougat. Battery is a beast.
Anyone have an issue with being able to use SD card for external storage? If I go in to settings/storage I can see my card and there are some apps on it. But I can't access the card using ES explorer or File Manager. It just doesn't show up. I was saving my photos to the card...or I thought I was.
I'm not using my card for that. Maybe this will bump so someone else will see it
Jamie789
