Moving to Android?
Android phones don't really need to be connected to computers; for the most part, everything is done cloud based. There's no iTunes so to say.
I've been on Android for 3 years, and have plugged my phone in maybe 5 times.
That being said, when you plug in an Android phone, it becomes a flash storage device, so it should work with any computer or os. It operates just as if you plugged in a USB flash drive.
To me, the main real world differences between the HTC One and the S4 are this:
If you want a removable battery and expandable memory via microsd, go S4.
Otherwise, go HTC One.
Everything else to me is the same, or so close that it doesn't make much of a difference.
Thank you for that :)
Hi everyone, well i did it, my iphone 5 has gone and i decided in the end on the HTC one, the 32GB memory and great build quality swung it for me, I'm just waiting for my network to send me a new sim card now, i'll sit and explore it later.....thanks to you all who helped me decide, I'm sure i'm going to have lots of questions :)
The next step is finding the comparative iPhone apps for Android. Because it's a different OS some things are just planned differently. I went from android to iPhone and then a year later back to Android. I thought iOS was a great OS, but just not for me.
Sent from my Nexus 4 using Tapatalk 4
It seems Moto X isn't available in the UK and on reflection the other two Moto's might be a little too old soooo... I am between two now HTC one and Samsung Galaxy s4, i can't decide so any help here would be great :)
Best bet is to try them for yourself and see what device you like more. Both devices are good in their own way. Nobody can tell you what you would like. The HTC has blink feed the galaxy has a nice display and touch wiz with air gestures. Try them for yourself has to be the best answer. What you like can be different from what I like.
Right now i am finding that i cant transfer my music in iTunes from my mac, its really annoying.
Search "iTunes sync" on the play store. Try some of the best rated apps for that you see and let me know how it goes. Wish I could recommend a specific one but I haven't tried yet lol
probang
