My galaxy s7 won't power off without pass code and won't restart
  • Start date Start date
A
AC Question
I have a galaxy s7 and my nephew change the Password and locked me out my phone I though I could just reset to but no !!!!! It's also a code on the phone to just power it off so I can't do that either !!!!! I need help how do I power off my phone that has a power lock on it if I don't know the password
You may want to take legal action against your nephew.
Yeah that sounds like a nasty situation...Just out of curiosity, do you have "Wipe after X failed attempts" enabled? If so, be careful of wrong attempts to unlock it.
I'm not saying to threaten your nephew, but I'd at least restate the severity of the situation and inform his parent(s) of the problems it's causing. Man I sound so old right there.
Sounds like you might have to manually reset the phone, potentially with Kies software or the like.
Then sign back in with your gmail account.
I'm having the same problem. Please contact me if u find the solution
Not sure if "find my phone" through Google, and then saying you lost the phone and asking to reset would work. From computer or another device. Good luck!
HEY GUYS! First time replying to one of these, so apologizes if this looks weird! So my customer is currently having the SAME EXACT issue so I looked here to find a solution but looks like you guys are still stuck. Well GREAT NEWS, I found the solution for my customer! So yeah, we need the phone turned off but we can’t because it still needs the security code. Instead of powering off the device, hit “Restart Device”, the device wont need a code for that so when the device restarts and the screen turns black, hold down the Power+Volume Up+Home Button until Recovery Mode pops up.
Thanks Frank from December. I thought of that but did not know when to press everything. Thank you so much
not sure if "find my phone" through google, and then saying you lost the phone and asking to reset would work. From computer or another device. Good luck!
this one is the best!!! Provided that you've all backed up your data! Thanks for this!!!!
The factory reset worked but apparently the previous owner had it registered to her Gmail and I can't go past that. Any ideas?
Thx in advance
OMG thank you sooo much!!! I really love you 😘😘
- Sign in to this Samsung at findmymobile.samsung.com
- Select the device in your account.
- Select "Unlock" option.
When you select the "Unlock" icon, a pop-up will read:
"Unlock your phone remotely when you forget your unlock method.
If you use this function, all of the screen lock information (Pattern, PIN, Password, and Biometrics) on your phone will be deleted.
Tap UNLOCK and enter your Samsung account password to confirm."
Good Luck Pplz!
If you can open your phone, just take the battery out.Then you can reset it.
LEricG
