My Kyocera phone won’t turn on but when it’s charging is a green light on
  • Start date Start date
A
Android Central Question
Trying to charge my Kyocera phone and it won’t turn on at all
Hi. I’m currently having this problem and cannot figure it out. I opened it up and unplugged the battery. I’ve held the power button and down button for ever. I have also held the power button, the down button, and plugged it in simultaneously and held for God knows how long. When I did that the only thing that popped up was a picture of the cord and it said low power and then it went black again. Oh and I even held the power button down for about a minute and a half. I am assuming it probably needs a new battery but, I would think it would still turn on if it was connected to power. It’s a Kyocera DuraForce Ultra 5G
Model:E7110. Any help would be greatly appreciated. Thanks
Welcome to AC!
Have you tried different cables and chargers?
Welcome to Android Central! Batteries can fail, so I agree that you should try replacing the battery. Also, unless you have a lot of experience opening up phones and replacing components, I would consider bringing it to a qualified technician, because there could be other problems as well, like perhaps the connections to the battery.
try press both vol bottom and power bottom for 10 second
yes I'm technical and today my boss give to me 120 pieces some of does come with this problem but I fix it just press vol - vol + and power bottom for 10 to 20 second the phone want to power off the green light and say low battery put to charger and ready.
Nazeer zaheen
