A ajbrickyard Well-known member May 16, 2010 50 1 0 Visit site May 29, 2012 #1 I just checked and it does not vibrate at all! and are the soft keys haptic feedback?
Hurleygm Well-known member Jun 23, 2010 354 29 0 Visit site May 29, 2012 #2 ajbrickyard said: I just checked and it does not vibrate at all! and are the soft keys haptic feedback? Click to expand... Yes they are. Sent from my HTC EVO 4G LTE using Android Central Forums.
cgardnervt Well-known member Jun 24, 2011 3,556 118 0 Visit site May 29, 2012 #3 On the HOX its a VERY unnoticeable rumble though. Does it rumble when you press the volume all the way down? If not you can try a reboot > hard reset > Return to Sprint in that order if it was me! Good luck and hope it works it self out for you! Reactions: ajbrickyard
