my play store has stopped working..
Re: my play store has stopped working.
I have a Sony S tablet.Re: my play store has stopped working.
I went to apps and cleared cache and reinstalled google play. Fixed it.
Thank you!! :D This totally worked for my phone! I'm hoping it stops the error that I get that starts out as google.apps....
I bought a samsung galaxy fame 6812i while overseas...having the same problem with the play store. Tried everything listed here. It opens and then immediately closes.
Please help. I have been using my samsung grand for less than a couple of week now and i can't open my play store. I have followed the procedures i read yet I can't still open it. There is a thing that keeps on popping saying, "Unfortunately, google apps stopped" what should i do? Please help.
Re: my play store was stoped working..
lauranari,
Assuming that you've tried all of the previous suggestions, you can also try thisView attachment 70916from any Home screen, press the Menu button, select "Application manager", press the Menu button again and choose "Reset app preferences".
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
YAY! THAT is the only thing that worked! Thank you!
can some body help me, my play store stop working on Saturday tried lots of different things with not much luck. taking in to account I don't know much about computers. looked at a few things on here this morning, and can now get on to the play store but can't down load anything. I am a bit worried about doing anything just in case I wipe everything off of the Samsung tablet please help or it is going to go for a fly out the window thank you..
The google play store on my dad's GS3 wont open either. I've tried to clear the cache but it wont fix anything and I really dont want to factory reset his phone. Please help.
your advice is exactly the corrective action for this problem. Having the same issue and I came across your post and it worked perfect, thank you.
A factory reset should be a last resort, John, not a first step. Spiral and Perv are on the right track.
In Settings / Application manager, scroll all the way to the right, then scroll down until you find downloads. If it is marked as disabled, tap that row, tap the enable button, exit and try the Play store again.
If it's not disabled, or you did the above and it still won't work. scroll down to Google Play store, tap that row, and tap the Clear cache button, then the Force stop button. Exit, and try the play store again. If it still doesn't work, repeat but tap Clear data, then Force stop.
If none of the above works, let us know and we'll try something else.
Hi. I'm facing the same problem. And the tips you have given (which is stated above) doesn't have an effect. :'(
Bianca,
There are other suggestions besides those - look through the whole thread (the previous 92 posts) before deciding that nothing works.
RESET APPS on the DOWNLOAD page WORKED for me...
THANKS
It started when I was in web based plapystore and told it to automatically downloads apps to my phone.
Hope this helps anyone else..
JPII
This worked for me, thanks a lot, was putting off the factory restore for awhile. Had the same problem, play store would just close as soon as it opened, and I couldn't download anything from any sites.
Go to your App Manager and scroll down to find your Download Manager, ensure that this has been enabled and follow instructions posted by another user telling you to clear your Caches and force stop applications in the Google Play App, Google services Framework and restarting your phone after all this has been carried out, it worked for me!
destypage12
