My S3 wont charge at all?!
Yeah I had an update as well. I had two and after that my battery dies so fast. And charges for hours. Once I use it the battery just goes down. I was charging it for over an hour it was on 64% Now its only on 74%. Also when I text or something the battery just dies down so fast.:'(:'(:'(
hi...,i charge to my s3 and the battery logo show the charging sign and percentage is not rising.it is that the problem or software or battery?please help me out from this one..thanks u so much
I had the same issue today that others have mentioned already - battery died and would not charge at all. I pulled the battery out and placed it back in, but when i tried to charge, it would turn on for a sec showing a battery bar or whatever, then turn right off. I tried charging via USB connected to my computer and the official wall socket plug - neither worked.
Luckily, my co-worker has the same phone. I swapped batteries with him to see what the issue could be. My dead battery was able to charge on his phone and his battery (not dead) was unable to charge on my phone, but my phone did still turn on with his battery. I guess the issue has something to do with the charging connectors or something.
So in the end, I just charged my battery on his phone for a few minutes to just have enough juice to turn on my phone. Once my phone was on, my phone was able to charge the battery again.
Weird.
Well, I seem to have a similar or unrelated problem. My Sprint phone is rooted. I switched ROM this morning. The phone had a lower battery level. Not completely drained. The phone rebooted after applying the rom in ROM manager, but, did not power up and stayed off. It is non-responsive to attempts to turn on. When plugged in the indicator light does not show it is charging? I've removed the battery and cleaned the terminals. Still nothing. I've tried various charging sources and still no indicator. No batteries to swap. Yet, I am certain it was not completely drained. Any experience and shared would be appreciated. I am about to call Sprint.
Weird.
Em, i had to same problem as you. But mine was maybe a little bit difference. Okay, when i tried to recharge my SIII battery, i used the charge port that has be supplied and given. But, after a few month(i started using SIII since August 2012) i notice that the battery icon that show up the battery percentage(a green battery icon that pops up when we connect to the charger) suddenly didn't appear. So, when i try to restart my phone a few time, Thank god its work! But, that not takes so long before its happen again(it did work when i tried the same method) and today, the charge port seem won't work anymore. So i had to use the USB charger that connect to the laptop to charge my device. It worked great but not sure if it will last forever. So in my cases, i pretty sure that the issues is coming from the Charge port. So maybe i should send it back to them so that they can fix it or give me a new charge port or I WANT MY MONEY BACK! but no matter what happen SIII seems great to me for its performance and accessbility.
Sorry for my english. i live in Malaysia so maybe my english isn't good. (A Hello from Malaysia):p
My S3 is 7 weeks old and the charging port is already bad. New one suppose to be coming today...refurbished to replace a less than two month old phone...WTH???
Check with samsung. They will honor the manufacturer warranty.
Sent from my Sprint S3 using AC forums
I had a similar issue with my sg3. It wouldnt charge when turned on while on the charger. and it was dying wayyy to fast. so for the dying part, I bought a 4500mAh extended battery. FIX AND A HALF! and for the charging issue. i tried using a different cable... same charger...different cable. and now its all gravy :) hope it helps
@Amitras....There was an exploit in the international version of the S3 that allowed a rouge app to root the device. It is possible (unlikely) that this happened. If they keep giving you the run around, do a factory reset, and boot into recovery and wipe your cache and Dalvik if possible. See if that helps.
I had similar issue, the battery was working correctly one day then it suddenly died, I tried another battery already charged and my phone turn on correctly, I tried the dead battery in another phone and it wont charge, what I did was:
1.I was trying wall charger and it wont charge,
2. without unplug the phone I press vol down+home+power for 15 seconds the phone vibrated multiple times but it wont charge.
3.I unplugged the phone from wall charger and plug in one laptop usb port and it started charging again.
im not sure if all steps are required of if they have anything to do but that's what I did and something made the battery work again.
hope this helps.
regards.
Sounds like your wall charger is not working. I don't think your attempt to reboot into download mode had anything to do with it.
I tried wall charger and USB port and none worked, also wall charger was working on the other phone. after the battery "unstuck" now is charging again in wall charger, USB and everywhere normally again.
the battery died for a while and now came back to life, I don't know why.
I am facing the same problem! Already contacted Amazon in USA, they sent me a brand new battery, and it still didn't work. Amazon has provided a good work in customer support.
After that I contacted Samsung USA, they told I should contact Samsung UK as the model is an international model. After contacting Samsung UK, received this letter:
Dear Maria,
Thank you for contacting Samsung Customer Support.
I?m sorry you are experiencing problems with your S3, namely the battery charging issue you have reported. I can understand your frustration about this as obviously it prevents you from using your device effectively.
Please note that our service centre in the UK can only repair devices that were manufactured inside the EU. As the country of origin for your device is outside the EU, it is not covered under the warranty policy for this region and cannot be serviced here.
Please contact the original retailer, or Samsung in the country of purchase, where they may be able to assist you further.
You can view all countries and regions available for Samsung support at the link below:
SAMSUNG
If there is anything else we can help with, please let us know.
Our Customer Support Team love feedback! Share your thoughts on this response by completing the survey at the bottom of this page.
Kind regards,
Jody
Online Support Team
SAMSUNG Customer Support Centre
I got nervous with this letter, so I contacted the service support again in USA! I wanted to know the right Samsung to contact. Here goes the conversation. It seems that the person was not able to provide technical support.
Stark: Hi, thank you for contacting Samsung Technical Support. How may I help you today?
Visitor: Hi
Stark: Hello, how may I assist you?
Visitor: Hello, I'm, facing problems with my Samsung Galaxy S3. The battery is not charging. I bought a new battery and the problem persists.
Stark: I'm sorry to know that.
Stark: I understand that the device is not charging when connected to a charger and the issue is persisting after replacing the battery also. Is that correct?
Visitor: I already got in touch with the assistance of the USA, where I bought the phone, and told me that my cell was manufactured in UK, so I got in touch with the assistance of Uk and they told me that the phone was not manufactured there, so they could not give assistance.
Stark: I'm sorry to hear that.
Visitor: yes, that's it!
Stark: I'm sorry to inform you that the device is not a US model device.
Stark: LiveChat support on Samsung.com is for the U.S. models only. Unfortunately, we do not have technical or troubleshooting information for non-U.S. models. For information regarding your product, I suggest checking the Samsung website for the country where the product was purchased. I apologize for the inconvenience.
Stark: You need to contact the Place of purchase or UK or Indian support for the assistance with the device.
Stark: I apologize for the inconvenience caused to you.
Stark: If the UK support is unable to assist you, please try contacting the Indian support or the place of purchase, they may be able to assist you with the device.
Visitor: sincerely want the Samsung solves my problem!
Stark: I really do understand your concern .
Stark: I would have surely helped you, if I had the information r. I hope you would understand our limitations. I don't want to provide any wrong information.
Visitor: I have one question
Stark: Please let me know the question.
Visitor: why you sent me to Samsung UK the last time we talked?
Visitor: last week I've contacted this same chat
Visitor: and someone form Samsung told me, as me smartphone is international
Visitor: I should contact UK
Visitor: now that I've contacted them
Visitor: they told me to contact Samsung US
Stark: The device is generally sold in UK or India, all the I9300 devices are sold in the UK or India. That is the reason we have provided you the UK support.
Visitor: and why UK cannot help me?
Stark: I'm sorry for the inconvenience.
Visitor: I already know that you are sorry
Visitor: and I need your help
Visitor: could you please
Visitor: give me the right number to enter in contact?
Stark: If the device is not a UK model device, they may not be able to assist you, in this regard you need to contact the place of purchase to get the device information and get the information to contact the specific Samsung support.
Visitor: who in the Samsung Inc could tell me if this model is a UK or Indian model?
Visitor: It seems that this model is an international model, unlocked by Samsung.
Visitor: I bought this device from Amazon, in a US link.
Visitor: Could you please assist me in order to tell me which Samsung I should contact?
Stark: You need to contact the Amazon to check the country of the device as we have only the information of the devices which are made or available in that specific country.
Visitor: They already told me that it is an UK model.
Visitor: And UK advise me to contact US.
Stark: Thank you for waiting. I'll be with you in just a moment.
Stark: I really do understand your frustration.
Stark: II would like to inform you that as the device is not a US model device, we can't provide any troubleshooting information or service for the device, as the warranty of the device is not valid in US.
Visitor: Ok, I already know that it is not a US model.
Visitor: I'd like to know which model is this?
Visitor: could you please tell me?
Visitor: So I'd be able to get in contact with the right samsung.
Stark: As I have already informed you that the device can either be UK or Indian model device.
Visitor: So you are saying that you don't know? It can br INDIAN ou can be UK?
Visitor: you are not able to assure the model by the information that I provided?
Stark: I'm really sorry, but the same model number device is sold in both the countries, it can only be confirmed by checking the IMEI number by the support of that specific country.
Visitor: I see
Visitor: Do you have the indian contact number for customer support?
Stark: You can contact the Indian support from the below link.
Stark: Support Samsung India
Stark: Please open the above link and let me know if you are able to access it.
Visitor: ok, thank you very much!
I hope Samsung India will be able to fix this! I'm totally disappointed with Galaxy....moving to iPhone!
I'm sorry you're having issues with the S3, and hope the iPhone makes you happy. But you should understand that part of the risk of buying a grey market product is difficulty getting support. The fact that you bought it from Amazon doesn't change the fact that it's a foreign market product imported by a 3rd party reseller, and not Samsung. Most companies (not just cell phone companies) don't provide support for gray market products. I suspect that if you buy a iPhone in China, and try to get it serviced in the U.S., you'll run into the same problem.
rambaka8
