My wifi connection needs help
Mar 24, 2013
3
My phone is connected to my house wifi and the signal is excellent but the problem is,when I tried to open facebook,it appears but when I tried to log in,it says 'error in connection,please try again later',when i tried to go to youtube it can load all the videos,but when i tried to play the videos,it says 'error in connection'. Same goes to google,play store and other online apps. I tried to:-
1.Taking out the battery and putting it back on (doesn't work)
2.Turning off the phone and the turn it back on (doesn't work)
3.Turned of the wifi for several hrs and on it back (doesn't work)
Help me please
It kind of sounds like you are locked to only connect to HTTP (port 80) and DNS (port 53) or there somehting else that restricts connection, check your router configuration
welma969
