NCAA Football Droid Wallpapers
Here are some from the SEC, will finish out the schools tomorrow...
Thanks so much! Do you use a program to make these?
There are a lot of different PC applications, but I use a fairly inexpensive product called Paint Shop Pro... I've been using it since version 7 and right now it's version X3. More time than not it's more about finding a good image using google, then resizing the image and putting on a good background image or color... this one was a little more difficult, but it's fairly easy once you learn the app.
can you do a Georgia one like the penn state one you did. on the grass with the logo in the middle of the picture?
I think you misunderstood me. Not that the work wasn't great, I just didn't like the photos used, for me personally. I wanted to incorporate our new rising "star" QB if possible, with the new uniforms, etc. I didn't mean your work wasn't great, as it clearly is. No offense intended man, I'm sorry if it came across that way.
Here's a couple better ones! I really like the way the QB wallpaper turned out :D
Reactions: DikaiaKnight
Well I can't find a picture of Georgia's stadium from the grass level like the Penn State one... Hopefully I can bribe you with some cheerleaders instead?!?! LoL ;)
kenster23
