Need a android compatible router for Iconia
I found out that the models of Belkin I was using were incompatible with Android - actually physically incompatible. I'm pretty much done with Belkin from here on out. They used to be the better product, but these days they seem to be the cheap one.
I think ya'lls issue (yes, I am southern) is that your router is using wpa2 encryption and it probably defaults to TKIP where your phone may look for AES, or vice versa. Your router might let you select both AES & TKIP together.
If your router continually goes from obtaining ip address to disconnecting this is likely it.
Or your router is set to WPA which my OG Droid wouldn't connect to...but it will connect to open, WEP, and WPA2. It didn't like the TKIP encryption for some reason.
dooleysdickulove
