Need a Car Charger With A Right Angle Plug
kg6bki#AC
Active member
Sep 26, 2010
32
I am currently using my EPIC 4G and charging with a Car charger. However the charger is sticking out of the top of the phone and the cord is putting strain on it. I am worried this is going to weaken the connector port.
Will This charger work for the Epic. It is "Angled" is what I am looking for.
Any Advice...If this isen't the right product can someone reccomend a charger with a angled plug
Genuine TomTom GO 520 720 920 Traffic 1.2A Car Charger - eBay (item 360324658677 end time Dec-08-10 17:46:13 PST)
Brian
not sure if the tom tom is like the garmin but the garmin ones angle back... behind th ephone. at least the ones i've seen do. i want to pick one of those up myself. not sure if you are looking for that or the ones that are angled to the side of the phone
edit.. just got a good look at that. looks like a mini usb.. too big for the epic. and it does angle to the side, not the back
You should be able to buy any right angled USB cord and hook it up with just about any ol' USB car charger
Most of these things are rated right about the same in so far as electrically speaking, especially if its made for other phones or something, so you shouldn't have too much of an issue.
However, that one you were looking for, will definitely not work. Mini USB is different than micro. Epic has a microUSB port.
kikoparra112
