[Need Help]Brick
ZAvonAJ
19
4
FIXED
Did a factory reset (long story). i have tried the KDZ and KP500 method and I always get to the point where it does the final reset and goes straight to my recovery menu (Xiona CWMA v1.2518.1). I have no adb use as far as i can tell from recovery and because the custom recovery shows I can not take it back to sprint. Any help?
Wait. Explain better. Can u get on your phone? BTW there's a sticky that helps you with some sorts of brick
Yes I can, I am able to use recovery and all but no adb support. What makes it worse is that I am not a rookie at this.
There is a stickied thread with instructions to unroot and return to stock recovery. That should fix your problem.
With rom tools or optimus s control center you can change the recovery without having to do adb
Sure fire method, A small hammer should fix it. We use them all the time at work. I prefer a two pounder myself but hey whatever fits. :)
Was able to fix adb to work, I can push files and all but when trying to access su in adb shell i get the /sbin/sh: su: not found
No, you did not say you tried the return to stock method as per the stickied thread. That uses a stock nandroid file and a working recovery partition which you have.
