Need help getting back to stock rom
Well I had a similar screen issue and took it to the Sprint store. They said they were going to fix it but then didn't have the part in stock, so they just swapped it out for a new phone. :cool: I was surprised to find out that they didn't run the OTA to get me to the latest FW rev, so I got it with hboot 1.4! Now I'm all rooted and ROM'd again with hboot 1.4 goodness and s-off! The Sprint guy was real familiar with the screen issue, so I think it may be more common that we are aware of. They were willing to do whatever was needed to get it fixed for me and that's all that really matters in my eyes. Take it in and have them look at it and you may just walk out with a band new phone!
Wow, nice customer service!
Unfortunately for me, My EVO 3d isn't under warranty or anything..
Maybe I'll have them look at it anyway and see what they say
I have followed the instructions to unroot my Sprint HTC Evo 3D listed here, but even though I can clearly see the PG86IM.zip file on the root of my sd card, hboot doesn't see it. I ran the fastboot oem lock command, it restarts showing "Relocked" at the top, I see it scanning for the zip file, but it doesn't see the PG86IM.zip file. Any ideas?
PG86IMG.zip
Sent from my PG86100 using Tapatalk 2
it should be named and look like this, do not add the .zip
PG86IMG
help....
I need help... anybody...
I got Evo3d gsm but now its not working.. its hung..
i want return to 2.3.6... old version... the version that i download is ICS...
jammed....
ANybody who know how to do it pls help me...
Pls teach me step A to Z.... PLEASEE,,,,,,,,...:(:'(
first what base build are you on?
download this RUU i have used this one, confirmed to work [ZIP] - RUU_Shooter_S_Sprint_WWE_2.08.651.3 - Downloads - Scott's ROMS
rename it to PG86IMG.zip place on the root of your sdcard, reboot to bootloader with your usb cable pluged already and make sure fastboot usb are highlighted, open your command propmt to the directory with fastboot and type fastboot oem lock follow prompts on screen when it shows relocked at the top reboot to bootloader without your usb cable pluged in , hboot should scan the zip and when its done it ask you if you want to install update, select update.
Ey friend i really need your help please! i have a evo 3d cdma sprint, i got the RUU you post, and i renamed it, i put it on the root os the sdcard, reboot to bootloader but i don't undertand how enter the comand, i guess it is the terminal but, what directory i need to put me in? on C? or where, i hope was clear my question. And my history is next... I'm root bla bla all fine (except i have S-ON) well, i tried flash a ROM it was installed but...my evo just dont pass the first htc logo with white screen, I tried to reset factory settings, but nothing, I tried with another RUU with .exe extension but is says it is the incorrect RUU, I come with you scary :( i think is happend the worst, please I need help!, Extra information, my bootloader es 1.50.0000 version
friend how do you put the command fastboot oem? on the windows terminal on C: ? or how i cant do it i need help please!
Bitterbuthappy
