Need help please!!!
Setzer
15
I'm hoping someone here can help me out. I've been trying to install the new 3.70.651.1 update and every time it fails. I then tried to do a manual update by downloading the file, renaming it to update.zip and installing it through recovery mode. Well, when I get to recovery mode it says "ClockworkMod Recovery". I'm guessing that the person I bought this phone from modded it? So, I select the option applysdcard:update.zip and it still fails. I'm guessing this has to do with this clockwork mod? Can someone please tell me what I need to do to get the phone back to its original settings so I can apply the new update. Thanks!!!!
Thanks!
Should I just download the RUU that has the latest update? The one with 3.70.651.1?
Thanks!
That would do it, if you want to unroot and use the 3.70 RUU.
I feel it's as much effort to flash a custom ROM with 3.70. If I were you, I would do that. You can use this one http://forum.androidcentral.com/htc-evo-4g-roms-hacks/49106-rom-rebirth-ac-rom-ashes.html or this one [ROM] 01/10/11 | SPRINT LOVERS | 2.2 | 3.70.651.1 | Radio/Wimax/PRI All-In-One - xda-developers (my preferred).
If your not comfortable being rooted just use the RUU in the thread poster above. Then go to menu/settings/system updates/chose HTC software updates and let your EVO ota update.
I flashed using the Sprint Lovers ROM you linked and it works great. Thanks for the info.
phatjoe824
