Need help regarding message settings!
ash001
6
Hi,
I just bought HTC one few days back. When ever I
receive a message it appears in viber too. Kindly
advice me how can I stop getting the regular messages
At viber. Looking forward to a quick response.
Thanks
You should have a setting in Viber that allows you to disable incoming messages from your default app. I've heard there may be some issues with this so I'm not sure 100%
Thanks badbrad17.................ur advice helped n i was able to figure out the solution:)
