Need help to Root Android 2.3.6 MTK6573 - 7 inch tablet phone
mvasu78
I bought a chinese tablet -Dolphin A70- 7 inch tablet phone Android 2.3.6 (CPU: MTK6573 ARM11 Dual core each 650MHz)
I need help to root this phone and also want to know whether i can upgrade this to ICS from 2.3.6?
Phone specs are below
OS: Google Android 2.3
RAM: 512M
Flash Memory: 8GB
Support TF card extend 16GB max
Display: 7 inch TFT LCD capacitive touch panel 800*480
Front Camera: 0.3 Mega Pixel
Rear Camera: 2.0 Mega Pixel
Battery: 4000mAh (Could be installed by yourself)
Networking: WiFi 802.11 b/g/n
GSM: 850/900 DCS: 1800 PCS: 1900
Can be used as a mobilephone
Below is the configuration when i saw "About Phone" in the Settings menu
Model-> e1107_v73_ht_84g
Androis version->2.3.6
Baseband version-> MAUI.11AMD.W11.37.SP.V17.F1,2012/03/14 16:54
kernel Version->2.6.35.7 (Sun Apr1 10:49:05 cst 2012)
Build number ->ALPS.GB.FDD2.MP.V4.5
Custom build version->133248561
You are going to have to scour the internet for a root process for your tablet, and, a ROM for your tablet. The less mainstream the device is, the less likely you are going to find either.
You might want to check slatedroid.com. There are a lot of ROM developers for different platforms over there.
bjlockie
