Need help unbricking
You can hold down Volume Down, Volume Up, and Power button together until your phone resets, then let go of Power button then hold down Power button again. This is useful for entering the bootloader mode where you can get into various system menus like fastboot, SBF flash, stock recovery, and more.
I pulled that off a website because I forgot how to do it as it's been a long time since I've had to. From there, do as you need which may even be a factory reset.
Never experienced these problems before so I'm going out in a limb here.
http://droidrazrroot.com/droid-razr-hacks/how-to-do-factory-reset-and-get-into-fastboot-menus-on-droid-razr/
Sent from my DROID RAZR using Android Central Forums
Could be why you bricked leaked versions have faults
I bricked my phone and need help . I can get it into ap boot and moto recovery thats it everything else is gone off sd sd ext and phone.
you said you dont know how your phone got bricked...this is how...trying to run "leaked"builds...it wont be long...just wait for the official
How so I sbf where can i get the file I was currently running the leaked ICS verision 211
SamPav
