Need help with 4g Issue
rbrown04
5
Here's my problem, for starters I'm new to Android so bare with me
Background: Rooted with simple root,running Froyo (running Toasted Delight FROYO 1.0), Kernal version 2.6.29-netarchy-toastmod-froyoized-3.7.8 natas@64bit-evil #9. Radio 2.15.00.07.28 WIMAX 26023
Problem is that I couldn't get my 4g to work after rooting. Found that if i went into settings and unchecked mobile network then checked 4g, 4g would connect, but as soon as I recheck mobile network i lose 4g. Any thoughts?
Does it work with mobile network unchecked?
And this would be better posted in the actual thread for Toasted's ROM. He personally could help you there.
Well, you can just use the HTC settings widgets and make a homescreen dedicated to setting widgets.
Among that I have 4g/3g/wifi/etc... so when you want to use 4g, just tap on 4g and uncheck mobile (which is 3g).
Vector
