Need Help with Program Check Box Fix
rdr6969#AC
Hello,
When you ask to view a picture and the list of available programs comes up it gives you the choice to check a box to always select a program. I did so, but then clicked on the wrong program. How do I remove this selection or change it to the one that I want.
Sorry for such a dumb question. Thanks for your help!
RDR
Go to Settings/Apps, select the app you mistakenly picked, and hit Clear Defaults.
ezmoving
