Need help with S6 Edge!
I-G-M
15
Hey guys I recently got the s6 edge and I am loving it. However as I came from an apple device and have a mac book pro, I'm finding it very difficult to sync my phone with iTunes to get my music on it very easily.
Is anybody in my situation?
What's the best solution?
How did you go about it?
All help is greatly appreciated
Thanks
Same exact spot as you but the Google Play Music app with the Mac companion is brilliant. The software companion on your Macbook Pro will automatically update Google Play Music on your phone if you buy new songs through iTunes. Google really put together a really seamless solution here.
Other choices for sure, in the link, but I really like the Google solution for this!
I use a software called mobilego, you can sync your itunes playlist to your android s6 edge.
That what I used.
I'd go with Google's Music Manager. It does everything automatically.
