Need help with texting audio clips
speedfreek64
112
Is there a way to link another folder to the menu that comes up when attaching audio to a text? I've got a custom folder loaded with my funny sound bites and I want to be able to access it when texting. Right now all my sound bites and music get lumped together which makes finding the exact sound bite a real pain. Hopefully someone has an answer!
You can install es file explorer and then you can browse to the folder and file of your choice.
Sent from my DROID RAZR using Android Central Forums
RockoAndroid3689
