NEED HELP!
Nojus Juozapavicius
So once I used Polaris viewer.It was installed automatically on my phone(Samsung galaxy s3 mini) when I bought it.Now I can't open .apk files.What to do?
Sounds like you used it as a default setting. Try going to manage applications, find Polaris, and uncheck the default area...
Sent from my XT912 using Tapatalk 2
I'm not sure if that's what you need to do. But, to remove defaults, you need to go into Manage Apps, select the app, then find something like Clear Defaults.
KidColoringPage
