R remarsh2003 Member Jun 24, 2010 14 0 0 Dec 9, 2010 #1 I'm on the 2.2 2.3.151 i'm rooted and used the bootstrap app now how do i get back to stock without root
sicario666 Well-known member Dec 27, 2009 2,931 366 83 Dec 9, 2010 #2 Did you create a backup of your stock settings? If not...you'll have to SBF. Its a quick and simple process. Just had to do it yesterday DXmeatclaws via tapatalk
R remarsh2003 Member Jun 24, 2010 14 0 0 Dec 9, 2010 #3 i dont have one and i tried to do the SBF but it fails every time i try it and cant find anything that will help
D Dfresh Well-known member Oct 4, 2009 45 2 0 Dec 10, 2010 #4 http://www.mydroidworld.com/forums/...droid-x-2-2-full-sbf-leaked-download-now.html What i used to get back to stock froyo then applied the update then use z4root to reroot Sent from my DROIDX using Tapatalk
