Need LED Notification to stay on past 5 min.
Maybe it's a bug/flaw that will be corrected in a update hopefully soon.... Or MAYBE it's why the TBolt was delayed soooooo long. Ya right. LOL
Well i'm pretty frustrated. I've got missed calls figured out using 'Easy Reminder' where the LED will flash for as long as necessary. So I'm good there.
SMS/MMS is another issue. No matter what I configure between Handcent and Easy Reminder I can not get the LED to flash consistently beyond 5 min. help please
Update. I MAY have this solved. As I said above I use Easy Reminder for missed calls. That alone works for keeping the LED flashing for those.
For SMS/MMS I DISabled Easy Reminder.
In Handcent I have my Notifications settings as: Vibrate: Always; Vibrate pattern: Normal; Blink LED checked; Enable Remiders Checked; Number of Reminders, 'Keep Repeating; Reminder Interval, 15. This last setting I think is the key. I had it at 5 thinking it needed to be the same as the stock LED flash limit.
Before the changes above I would get a vibrate reminder and inconsistent LED flash after 5 min. It's entirely possible that Handcent also updated their app's handling on the TBolt since last Thursday as they have had at least 2 revisisions. Good luck and please let me know if this works for you all.
Nammna
