Need serious help!!
ummmm
does your mac automatically uncompress files when you download?
what version of osx are you using?
thanks man, I really do appreciate your help. I'll do this at work tomorrow, use a PC there. this is driving me nuts. How could I tell if my phone is bricked?
if it's bricked it wont turn on :)
it's not bricked. if you cant get it with the toolkit and fastboot you should be able to get it with odin mode. odin's like a fail safe mode, amongst other things.
I'm not keen to this kinda stuff.. after looking at that toolkit, it would take me a good amount of time which I don't have.. I'll try Odin mode tomorrow morning at work. I just need to know where I can find the samsung drivers as in #1 of the instructions
I beleive this is one of those instances where I would need someone to show me what to do, and then I'll have a better idea on how to do it..
the toolkit is the easiest way to get the drivers installed, or use wugs toolkit stickied in this sub forum, or follow cyber warrior's instructions found here:
http://forums.androidcentral.com/ve...ock-bootloader-root-verizon-galaxy-nexus.html
aside from that, i dont have a pc and havent used one regularly in ten years, so i'm not the one to walk you thru it, but if you need further help i'm sure someone here will answer any questions you have.
that said, i know lots of people have raved about the toolkits (both the one i linked before and wugs which is stickied here) - they do all the work for you - you basically download, select what you need to do, and it does it.
so, if i were you, i would look into it - its not gonna take that long, especially if you read about it now if you have time, then execute it tomorrow.
Sounds like a plan. I'm reading into it now.. i'm at the part FLASHING A ROM, RADIO OR KERNEL VIA CWM RECOVERY. I'm confused at this point. After going through all of this, what do I do after step 2 in those instructions
Mr2Shorty3
