Need some good mods
is one of the tweaks not compatible with XperiaICS or rather ICS, i probably should of ask before i flash it....
i hate trouble shooting, now these im just saying boot up on XperiaICS with the zv9 update and were flashed by TWRP rec, i dont know if they actually help- TweakZV6, VM670_eglpatch, Timescape, SuperSU-v0.88-CWM, Sony_xLoud, MegaBassbeats, Amphetamines-02-signed, Adrenaline_Boost_V3, Adrenaline_Engine_4.2 all work i don't know if they help
Some you may not be able to tell if they're there or not. I've flashed many of them and the one that jacked my phone up was Mega bass beats it doesn't work on cm9
not entirly true becuase iv flashed megabassbeats on a couple cm9 roms and it works for me just mount system before flashing each tweak
So did you update this today tgl? Just wondering it might be nice to have all these on hand and thank you very much
tap tap tap
I'll post in the newer thread with second post. I'll update the zip in a few :)
What does the Zv6 tweak do? i looked it up on google and came up dry.
couldn't find anything on the vm670_eglpatch either. what does it do?
Look for Supercharger by zeppelinrox on xda.
Verstuurd van mijn GT-P5100 met Tapatalk
Does any of these tweaks make a noticeable difference? I just installed them and I don't seem to see anything new except that my phone boots slower and feels a bit bogged down. Running Harmonia 2.9
looks like it's been patched and improved...i tried the original one that was specifically patched for the P500 and it wouldn't completely install...always something missing.
may check that out...I wonder if this time I gotta freeze DSP Manager...?
I use the Pimp My Rom tweak package from xda. Has pretty much everything in it. Alot of people reported issues, but i haven't had any issues and i'm using all scripts and tweaks except,for dalvik tweaks. My phone is now lightning fast and buttery smooth. Running on latest Quatramus AOKP.
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
@TGL...thanks for the tweak pack. Using some of these made my phone even more unbelievable :D
I was supposed to update that with more tweaks, but instead, I ended up losing them. Geekymod is one, its in the Galaxy Ace section of XDA. That's all I remember, helps release ram.
Sent from my HTC One V using Tapatalk 2
Can you flash all of these without messing up your phone ?
As long as you make a backup first, then there's nothing to worry about.
Sent from my GT-P7310 using Android Central Forums
Alright, but can I flash all of them at once
If you do it that way and everything works, the great. If something doesn't work, then it may be difficult to figure out which worked, and which didn't. I do them one or two at a time, but it's up to you.
So I took your advice and I flashed one by one, and amphetamines took away my root, good thing I had a backup
liquidsnake757
