Netflix.apk runs on OPTIMUS...
Just out of curiosity, do any of you with the optimus s on stock rom or other wise have problems with the video colors being slightly off and a green bar at the top of the screen? There is a problem on the stock optimus v, but not aospcmod rom.
My friend's Stock optimus V has the strange colors, and the green bar at the top. My Optimus S doesn't. I have stagefright and hardware acc enabled, he doesn't. I think that has something to do with it...
it says you're using CM7. is he?
CM7 doesn't have this issue so that might be it
I have netflix streaming on my rooted Optimus S rebornRom 2.1 using the no check. Apk from xda forums. I have the green bar at the top. Idk about what stagefright is but gonna mess with it some and see if I can get rid of it. At least it is watchable and I couldn't watch anything before...
I am using Xionia CWMA...
I am running reborn, and just loaded the non clicked version too. I am able to run it but again, the green bar. It is only the very top edge of the screen (viewing landscape automatically) and easy to dismiss. But it would be nice to find a fix for that.
TheGreatApe00
