Netflix working on stock iconia 3.1 with root
dolphin crashes when going to player. new to this rooting stuff and don't know where to go from here.
Not sure root has anything to do with your issues. May I also suggest Wunder Radio as it supports xm streaming. Since xm uses flash maybe there is an issue there since it is crashing both browsers. Wunder Radio will also open up a whole world of other stations. Not a solution of course but a way to get running. I also have had great luck with Pandora.
found the problem, in the lib directory when i changed libnvomx.so to libnvomx.bak had the issue with flash, changed it back to libnvomx.so and it xm works again.
Does the Netflix files break anything else on the tab? I thought I had read that? I had been using PlayOn to access Netflix but I can't get it to work anymore.
I haven't experienced any issues yet. The only thing I really haven't tried is Bluetooth so not sure there...
whhghjk7788
