network issue problem in oneplus 3..
nazar ali1
Facing a horrible network issue problem on the first day of purchase... Can't able to connect to 3g or 4g in India... Only 2g network is connecting
Have you tried checking APN settings? Made sure the wireless bands are compatible with your network?
Bhai..try restarting your OP3 with selecting 3g in networks..
It will solve your problem..
N if you have any more queries please let me know..
Op3 hangs on toggling between screen or opening setting or google now crashes all on the first day
I bought this phone from the only seller amazon in India and I didn't expect this one my first use phone is hanging and get to auto reboot and when it comes back it happens again... It is due to any bug in oxygen os or could it be a issue with this particular device... I didn't buy such a monster performer to face such issues...and feeling highly disappointed and planing to return this phone... Any suggestion or help
Re: Op3 hangs on toggling between screen or opening setting or google now crashes all on the first d
I had the same problem the auto rebooting issue is with the op launcher so I am using nova launcher so no more auto reboots. But the log issue is yet to be solved, I contacted the tech support they said re flashing to stock firmware will solve all the problems yet to hear more from them.
KidColoringPage
