Network Problem??
Joker35
211
4
I am wondering if it is my phone or the mobile network.
I will use my phone on the mobile network 4g/3g. When I am done I hit the lock button on top of the Rezound. Let's say 10-15 minutes go by I hop back on the phone, unlock it and my mobile network is off. I will have good status bars at the top, but no 4g/3g icon. I even put a mobile widget on my home screen. I then hit the widget to turn the network back on, then i get the 4g/3g network icons. Also if I lock my phone and come back to it within a couple of minutes the network is available. It's just when the phone sits for more then 10-15 minutes.
Is the phone going into asleep mode? If it does, shouldn't the mobile network come back on when the Rezound wakes form the lock screen?
Also my Rezound is set to High Performance.
Thanks ahead for any advice.
Try to disable sleep mode.
Settings>Power>Enable sleep mode.
Select "Never" and see what happens.
Reactions: Joker35
Technically the network shouldn't ever be off if you're on high performance. Try changing sleep mode to never and mobile data to always-on. If that doesn't work, you might want to think about a factory reset.
Thank you!! I think that may have worked. I will know for sure when I leave work. Work gets crappy signal.
joelkmason
