New Bass Control Feature for Pixel Buds A
Update here too ...it took longer than my December update lmao
I like the bass slider. Was happy with the old toggle but with the slider I can adjust to suit the music I'm listening to.
Didn't notice much of a difference
After a bit of testing I agree. I can hear a little improvement but not as much as turning on Loudness Compensation on does. At least it is a step in the right direction.
I finally got the app update this morning. I'm finding the new bass slider is great!
Is it normal for the right bud to show way more hours in battery life than the left? It's like 9.5hrs for right and 6.5 hrs for left. Doesn't seem right
If you put both buds into the case when you're done using them they should both recharge to 100%.
The bass slider on my Pixel Buds A has a flaw where every time I use the earbuds I have to reset the bass slider to my desired setting. Every time I'm done using the buds and return them to their case the next time I use it the bass setting has been set to neutral and I must readjust.
Google has acknowledged the problem and is going to send out a fix in an upcoming firmware update.
https://www.google.com/amp/s/9to5google.com/2022/06/29/pixel-buds-a-series-update-bass/amp/
Hmladlossau
