New COD Mobile on P40 Pro, help help to get it working.
garlow
67
Hi all,
Can anyone with a HMS device tell me how to get COD mobile to work, I've seen people playing it on them but when I've tried to install via petal search it comes up saying I cant because no playstore.
Does this mean I'm locked out of any game that uses micro-transactions because it requires the playstore to pay?
Thanks
Hi all,
Thanks
Try Aptoide, it's been working for me for everything that doesn't yet work on App Gallery/Petal Search.
Hi all,
Thanks
I don't play COD, but I tried with Hearthstone (they also have micro-transactions, facilitated through the Play Store), everything works fine other than buying stuff with real money. A workaround for me is to top up my Blizzard account on the browser and then use that money. I don't know whether you have something similar in COD, but it's worth giving it a try.
Thanks for the reply! Once I get it working i'll see if that's an option!
Ok will do! Didn't think id need anything outside of petal search but i'll give it a go and let you know!
Yeah, it's been really good. I found all my banking apps and even apps from other countries.
Can you keep this post updated so I can try it, I've just got into Cod and want to see if I'm good on it on my mobile too
Got it working! Aptoides download did it for me, works totally fine unless you wanted to buy the currency as it seems to link with playstore to do that.
Dunno if anyone plays minecraft but i was looking to put it onto my MatePad Pro but couldnt find a working version on APKPure or Aptoide. I then bought it for £5 on Amazon App Store and Voila it works just fine
What type of banking apps of you don't mind me asking, any barclays?
Depends where you are, I found the Spanish one and one without any description. I don't have an account to try it out soz. But Barclays is known for doing their own thing, they are not even on Google Pay, only Apple. (Uploading a pic with my results) .
Sweet, glad it's working for you too.
Amazon app store is a great shout too, does petal search not utilise it already then?
yeazwida
