New update for Note 9 with May
I don't think it is a widespread issue & never had it happen here.
Wow, that sounds really annoying. I would probably suffer a factory reset on that one. Is that a widespread issue?
I'm in the UK using a Note 9 purchased directly from Samsung so zim free, and awaiting this update.
Right now I'm on the April update.
Seems some are experiencing issues with the May update such as the phone freezing.
I'm on the phone with T-Mobile adding another line onto my account and I'll use it on my Note 9 all of this week. So far in the hour since I've updated to the May 1 patch, it seems to run just as good as it dod before the patch.
Know the s10's are having issues with Exynos May updates, did not hear of any Note 9 issues yet.
May patch for S10 is removed by samsung because it has problems, so it was never and issue for Note9.
i am glad i didn't get the S10 Plus Way too much problems that phone is having.
I have two S10+ phones with zero problems. I think the problems are only with the Exynos model. I have the SD version. The SD version is probably the most stable and dependable Android phone I have ever used to date. The battery life alone is even better then my Note 9.
Yeah i did more research on the web and your correct, also my wife has the S10E Snapdragon AT&T and no issues at all, But i'm still happy with my Note9 need my spen since i use it a lot.
Love my note9 got send it in this week for charging port dont work with cable , only wirelessly, but my s10+ on tmobile may update no issues so far .
Did you check the port to make sure it wasn't filled with lint and dust? I had this problem with an iPhone 6S+. The plug wouldn't stay in and half the time, it wouldn't charge. I took a toothpick and pulled out tons of gunk. The plug worked perfectly after. Our pockets are really dirty and dusty.
Yeah , nothing in the port , had my led light in there checking it out . I have couple other Samsung chargers and brick nothing . I tried last thing factory reset and still nothing .
moba8788
