Newest leak
Okay can I apply just update even though I am rooted and unlocked I read somewhere that this update will not work on rooted phone, fact or fiction?
Sent from my ADR6425LVW using Android Central Forums
You have to relock I know. Someone else can say if there is anything else. I think you might have to flash stock recovery as well. I need to know too for whenever I get off my lazy butt and flash the .10 leak lol
Someone posted on the RAZR's ICS that Verizon removed the LTE/3G toggle menu and forced their RAZR to stay on LTE full time. How about the Rezound's version?j
I should know this, but do not. When attaching your phone to your windows based computer, does the phone become the "F" drive or the "G" drive. Want to install the
latest leak. Tired of waiting on the OTA ICS. Thanks.
It depends on the machine. One will be labeled htc storage, that is the internal drive the next one will be unknown and that is the sd card
Rezound via Tapatalk 2
It appears that all that went away when I downloaded and Installed the leak.....I got nothing showing up on my comp except the phone itself when I plug it into the computer
Seems that way since the *#*#4636#*#* is no longer accessible
You can still force your phone to CDMA only via settings->Mobile network
select Network mode, which allows you to select LTE/CDMA or CDMA only
Well my computer(windows 7) recognizes the phone but shows a "F' drive and a "G', both as disk drives. I cannot move the leak to either. What am I doing wrong? Thanks
I went through the flash process for the latest leak with no results. fastboot was unchecked
and the PH98IMG.zip was definately on the ext. sd card. My phone has been re-locked, so is that the problem.
Are you s-off?
From my XxX rated Rezound
No that won't hurt. Did you flash the pmig file twice and use the firmware patch?
partugyan
