Nexus 4 - Franco Kernel, my experience
Re: Franco Kernel, my experience
you mean i can get less screen on time than on stock? :D
Sent from my Nexus 4 using Tapatalk
Hell no. Just that you might only get 4-4.5 hours depending on your usage and signal
that would be also great, every minute more than my stock can get would be a great result for me
I understand. Just don't expect 6 hours for you. Just because other people are getting that
Used the free app to autoflash the kernel and that went great. After flashing I figured I'd like to try the paid app so I bought it and tried to open it, but it'll force close immediately as I try to open it.
I'm running ART, and I think this might be the problem as I've been succesful in opening the app on Dalvik.
How come the free app supports ART already but the paid app doesn't?
Sent from my Nexus 4 using AC Forums mobile app
The paid app does work on ART don't know why it doesn't work for you.
This may be a "noob" question, but how exactly do I go thru the steps to upgrade to Franco.Kernel? I am ONLY hearing good things about it and I would like to change for the better. Any info on this would be great.
Easiest way is to use the FKU app (franco.kernel updater) to use it. Be sure to be rooted.
rosannejoy555
