Nexus 4 Kitkat OTA update started... (image attached)
what icon?
I'm not sure. There was something I didn't recognize in the left hand side of the status bar, and when I pulled it down, there was a message that I had an update available. I think it may have been the "system update available" at the bottom of https://support.google.com/android/answer/168454?hl=en but I really didn't look that closely. (Hard to make out those little icons with bifocals sometimes ;))
Still running perfect after installing from clearing framework.
Already read that. Still have not had issues since I did that same way to hey 4.3. Never have do a factory reset.
Posted using Nexus 4 via Android Central App
You guys are lucky then. I didn't want to start an argument, but better safe than sorry.
Good luck with your KitKats!
I never had to do a factory reset either BUT my Gmail accounts no longer synced and there were problems in buying apps from the Play store. Deleting the Gmail accounts and then re-adding fixed that. Many notifications from apps no longer worked. I had to delete the apps and install again. Sync also no longer worked and I didn't realize it right away. It took a while to get everything to work again but you never have to do a reset.
Got downloaded 4.4.2 finally and installed on my Nexus 4.
Now the issue is when I switch over to ART it says No Sim inserted and then the phone freezes and I have to reboot so had to switch back to dalvik. Any idea what could be wrong?
Sent from my Nexus 4
Weird.. For me it just asked to reboot and during start up it converted all apps to ART compatible format. That took good 15 mins. That's all. Till 4.4.2 whatsapp wasn't working with ART though. Now is working. Try removing and re-inserting sim card.
ips gaming 88
