Nexus 4 Screenshots: Share them here!
I do use gmail, but only for my personal emails. At work we use an exchange server. It is the work emails i would miss the most since i am more productive for receiving them
What are you using to display weather like that? Does it open a weather app when you click on it?
Minimalistic Text. You can create your own widgets and launch anything you want from them. Currently the time / date and weather is one widget that launches Business Calendar. But you could easily make two widgets out of it. For weather details I just use Google Now.
this is my 4th try and i think i finally got it were i like it
which one do you guys like better
Wanted to share it with AC folks: The Corner Text Home Screen
Going to try to replicate it without rooting (I know I can't change icons, but will attempt to get close to it looking like on LH.com)
No need to root in order to change icons. Just install Nova launcher. Then you can download icon packs and change the icons by holding down on them and selecting edit.
First post here, been inspired by the other posts.
The only screen I'm not too sure about is the weather / toggles / games screen.
Running Nova, SimpleText and MetroIcons
Naudiz
let me know if you find the Pulp fiction wallpaper
Found it but I'm having problems with the size. Here's the link maybe you can fill me in on the correct size to use so it displays the whole picture on my main home screen.
http://wallpapertube.com/tv-and-movies/pulp-fiction-funny-pulp-fiction-wallpaper
man iam having that same problem the hole picture doesnt fit the screen, if u find out a way to fit the hole picture in let me know
The correct size it needs to be cropped to is 1280 X 768 if you want it to just fit one screen.
pimped out
bruce03510
