Nexus 4 Screenshots: Share them here!
I wish there was a way, and correct me I'm wrong and there is a way already, to be able to just download the way a lot of you have your home screens configured. Nova lets you backup your home screen config. so maybe there IS a way to just use that to run this stuff.
Yes but it still does require some work to set up the widgets etc. Check out www.mycolorscreen.com/badbrad
Simple one this time. I'm getting more intricate this weekend.
Nova Launcher Prime
Zooper Widget
Simple Text
Vapor Ice HD Icon Pack
I'm looking for the Central Nexus icon of this dock :
55018d1356974299t-nexus-4-screenshots-share-them-here-uploadfromtaptalk1356974296400.jpg
If anyone had this, or know where i can find it... ;)
Thx
First attempt at this, but I'm going for a minimal'ish type design. So far I only have a weather widget, with scroll enabled dock. Recommendations always welcome!
63633d1363877959t-notification-widget-recommendation-uploadfromtaptalk1363877956211.jpg
63635d1363878163t-notification-widget-recommendation-uploadfromtaptalk1363878204526.jpg
This is what I look at....
I tend to fiddle with home screen layouts more than perhaps is healthy! This is what I've settled on at the moment though and actually stuck with for a while
Fairly simple.
Using:
Scintilla LWP
HD Widgets
Flashlight Widget
Hotspot Toggle Widget
On notification bar:
Battery Guru
Battery Widget Reborn
Dodol
Network Speed
CPU Stats
Accuweather
Weatherbug
(Currently evaluating weather apps to decide which to keep.)
And I just enjoy tinkering with it. :)uploadfromtaptalk1364070848263.jpg
Looks good. Have you tried to remove the dark background and blue line on the weather widget? It may give that cool background more depth.
Like this? I think you're right, but I never really noticed it before. And yes, I ditched the search bar, too.
Waaaaaay better. It looks like a complete picture now. Really like it. You could also try using the SMS white icon set. It's nice and clean and would really suit this design. Check them out on the play store. You can even adjust the folder icons if you use Nova launcher.
Kind of like this?
I think when I find the right icon set I'd be happier. The background is a picture I took on the beach at sunset two years ago
tinni99
