Nexus 6: Screenshots
Super minimal! But how did you put together the strip that looks like a separate quick launch bar above the page indicator? Is that your actual Dock set as an overlay?
That strip is a Google Keep widget with different ways to take a note or make a list. I have folders with just my most used apps in the dock. Swiping up opens the app drawer.
Thanks! That's great to know since I use Keep every day. But how did you end up with white icons on a dark background? The only option I have is a solid white bar, and I can't find any editing options for the widget.
I'm using a dark Layers them which makes the UI and most widgets dark.
I went ahead and bought Nova Prime so I could enlarge the icons and get rid of the labels. I really like it.
My Android N Beta home screen. Because we all know it really ought to be Necco Wafer.
Looks more saturated in person.
Ashok Dharshan
