Nexus 6P not receiving texts in car via Bluetooth
johnmcc0710
514
My 6P works fine with Bluetooth in the car except for texts which I miss. I have a 2013 Accord. Are texts working for others? Maybe marshmallow?
Re: Texts in Accord
What do you mean by text miss? It doesn't read your texts?
Re: Texts in Accord
Correct texts are not read they don't come through at all calls work. I even tried the stock app. Always worked with my S6
Re: Texts in Accord
It could be that the car needs a firmware update. Take a look at this thread and read through it to see if it helps: http://forums.androidcentral.com/nexus-6p/603641-nexus-6p-bluetooth-issues-car.html
It was started for calls. However, may also address the text problem that you are having.
There is no firmware update available according to the dealer
Prince08900
