The sound suddenly stopped on my new Nexus 7 last night. Sounds are enabled in settings and my apps have sound turned on. Any suggestions?
Sir, did you check everything in Settings>Sound? Tap everywhere in "Sound" until you find where it asks you for the volume of notifications, apps, and sound. If you're looking for the setting where it makes the sound when you tap, it should be in there too. Good luck!The sound suddenly stopped on my new Nexus 7 last night. Sounds are enabled in settings and my apps have sound turned on. Any suggestions?
By reboot do you mean turn it off and then back on? If so, yes. I haven't tried a reset yet; leaving that as a last resort.
All fixed!!!! Thanks!
How did you fix it? Hope not a reset and data loss! Just happened to me today. Done a few already.
- - - Updated - - -
