Nexus 7 (2012) bootloop help!
Kyle Jackson
Ok so i rooted my original nexus 7 which was running android 4.3, and so i decided to install a custom kernel. well i didn't know that kernels weren't compatible with any android version (stupid, i know) and installed franco kernel 6.something and now its stuck on the glowing X animation and i cant get past that. anybody got a fix or am i just screwed?
Hi, Kyle Jackson...
No... you're not screwed. You just need to flash the Jellybean 4.3 stock boot.img. Which by happy coincidence I extracted from factory stock recently for my own requirements (I decided to go back to stock kernel, after running franco for a while).
Anyway, here it is...
http://dl.dropboxusercontent.com/u/37483979/jb43_bootimg.zip
Just unzip the boot.img on your PC, and fastboot flash it with...
Code:
fastboot flash boot boot.img
Good luck.
Rgrds,
Ged.
Jon OapostraphyBrien
