A bug activated by Skype and other applications in 4.4.2 is causing high battery drain and overheating. It looks like the bug is in the camera software. Maybe this is the root cause of the crashes and reboots some people have seen when using the Nexus camera. There is a fix from Google coming for Nexus devices. If you are not on a Nexus device, then you still may have the issue, but the fix has to come from the device's manufacturer.
It sounds like the bug is related to the chipset and effects other devices with earlier release of Android. Specifically the article mentions the Note 3 with 4.3
KitKat giving you battery drain problems? Try uninstalling Skype, says Google as it prepares a fix | ZDNet
